Threads: 27
okay i would like to know how to do 2 things
1.make the edit a color(just like where you type make that a color)
2.make where you type in an edit the text a color
I would really appreciate if anyone could help
Thanks
Function Dialog_edit_colors
\Dialog_Editor
if(hDlg) goto messages
str controls = "3"
str e3
e3="red text"
if(!ShowDialog("Dialog_edit_colors" &Dialog_edit_colors &controls)) ret
;0 "" 0x10C80A44 0x100 0 0 145 99 "Form"
;1 Button 0x54030001 0x4 4 82 48 14 "OK"
;2 Button 0x54030000 0x4 56 82 48 14 "Cancel"
;3 Edit 0x54030080 0x204 8 38 128 16 ""
;DIALOG EDITOR: "" 0x2010601 "*" ""
;messages
int textcolor=0xff
int backcolor=0x00ff00
int-- hbrush
,hbrush=CreateSolidBrush(backcolor)
,ret 1
,DeleteObject hbrush
,case WM_CTLCOLOREDIT
,if(lParam=id(3 hDlg))
,,SetTextColor wParam textcolor ;;text
,,SetBkMode wParam TRANSPARENT
,,ret hbrush ;;background
,;Similarly, you can use other WM_CTLCOLORx messages for other control classes and dialog itself.
another example
Function Dialog_font_sample
\Dialog_Editor
;Shows how to set fonts and colors.
str controls = "6 3"
str lb6 e3
e3="Text"
lb6="item1[]item2"
if(!ShowDialog("Dialog_font_sample" &Dialog_font_sample &controls)) ret
;0 "" 0x10C80A44 0x100 0 0 173 99 "Dialog Fonts"
;4 Static 0x54000000 0x4 10 22 48 14 "Text"
;6 ListBox 0x54230101 0x200 104 20 60 34 ""
;3 Edit 0x54030080 0x204 10 38 82 16 ""
;5 Button 0x54020007 0x4 4 6 166 54 "Text"
;DIALOG EDITOR: "" 0x2020103 "*" "" ""
;messages
,__Font-- f
,f.Create("Courier New" 14 1)
,f.SetDialogFont(hDlg "3-5")
,f.SetDialogFontColor(hDlg 0xff0000 "3 4")
,__Font-- f2
,f2.Create("Comic Sans MS" 7 2)
,f2.SetDialogFont(hDlg "2")
,__Font-- f3
,f.SetDialogFontColor(hDlg 0x008000 "6")
,;note: __Font variables must not be local because they must exist while the dialog is open.
,;note: in a dialog, use different __Font variables for different fonts.
Threads: 27
Thanks Gin
the first one with color edits works perfectly
but in the second one it errors on the first __Font--
it says unknown identifier
could you please fix it or tell me what to change?
should it be an int?
Thanks again bro
Threads: 27
okay im trying to make one with multiple color edits
this is the code
but only the first one works
do you think you could please fix the code
thanks
\Dialog_Editor
str controls = "3 4 8 9"
str e3 e4 si8 si9
si8="$qm$\findhtm.ico"
si9="$qm$\findhtm.ico"
if(!ShowDialog("TEST_COLOR" &TEST_COLOR &controls)) ret
BEGIN DIALOG
0 "" 0x90C80A44 0x100 0 0 169 95 "Logginer"
2 Button 0x54030000 0x4 114 70 48 14 "Close"
3 Edit 0x54030080 0x200 46 16 116 14 ""
4 Edit 0x54030080 0x200 46 44 116 14 ""
5 Static 0x54000000 0x0 32 18 48 12 "ID"
6 Static 0x54000000 0x0 12 46 48 12 "Password"
7 Static 0x54000000 0x0 20 72 74 10 "THIS IS A TEST"
8 Static 0x54000003 0x0 6 70 16 16 ""
9 Static 0x54000003 0x0 94 70 16 16 ""
END DIALOG
DIALOG EDITOR: "" 0x2020105 "" ""
messages
int textcolor=0xFF
int background=0xF
int-- jbrush
if(message=WM_INITDIALOG) DT_Init(hDlg lParam)
int param=DT_GetParam(hDlg)
,jbrush=CreateSolidBrush(background)
,ret 1
,case WM_DESTROY DT_DeleteData(hDlg)
,,ret jbrush
,if(lParam=id(4 hDlg))
,,ret jbrush
messages2
,case IDOK DT_Ok hDlg
,case IDCANCEL DT_Cancel hDlg
don't need two "case WM_CTLCOLOREDIT". Just remove the second.
__Font has been added in some of recent QM versions. Your older QM version does not know what it is.
Threads: 27
Thanks bro that worked perfectly
is there a way to just make the text color change and not even mess with the back ground
for example not even having the create brush or anything
Thanks
Not sure is it the best way but works. Replace
ret jbrush
to
ret COLOR_WINDOW+1
And remove all code where is used jbrush.
Threads: 19
Is there a way to make this work dynamically? For example, if I click on a box, have it turn colored, but when I click on a second box, have the first box turn white again, and the second box turn colored?
replace
to
if(lParam=GetFocus)
Threads: 264
When I have an colored background in an editfield, the text within that editfield becomes unreadable when it is being modified.
Example, put cursor somewhere within the asterisk and edit/modify the text.
Function tst_backgr
;0 "" 0x90C80AC8 0x0 0 0 224 136 "Dialog"
;3 Edit 0x54231044 0x200 32 19 152 87 ""
;DIALOG EDITOR: "" 0x2040601 "*" "" "" ""
str controls = "3"
str e3="AAAA***AAAA"
int textcolor=0x000000
int backcolor=0x00ffff
int-- hbrush
,,hbrush=CreateSolidBrush(backcolor)
,,DeleteObject hbrush
,,if(lParam=id(3 hDlg))
,,,SetTextColor wParam textcolor ;;text
,,,SetBkMode wParam TRANSPARENT
,,,ret hbrush ;;background
EDIT:
Is there a redraw that must be done to avoid unreadable text?
It seems multiline Edit controls don't redraw.
Replace
with
SetBkColor wParam backcolor
Threads: 264
